I’m consulting on a project where an active low-pass filter with a cutoff around 40…50 kHz is needed. Filter order/type would be 4…6th, maximally flat group-delay (no, this does not mean Bessel, but almost). The filter is to be used for reference and calibration, which means that it must be very precise (in terms of adherence to ideal transfer function and gain). A digital filter (A/D->DSP->D/A) is not an option in this application.
These topologies for cascaded 2nd order filters were evaluated:
“Positive finite gain” aka “Sallen-Key”. This was dropped immediately due to its extremely poor performance (rejecting this topology is a “knee-jerk” reaction with me).
“Infinite gain” aka “Multiple Feedback/MFB”. Better: with a sensible design, component sensitivities can be kept reasonably low (which is essential for a precision filter). However, high-frequency feed-through is also inherent. And does infinite gain really exist?
“Negative finite gain”. This is where my real questions start. This is a topology that I’ve not seen in the wild, white papers or application notes are basically non-existent (I’ve searched, but perhaps the filter is known under another name). A mathematical analysis of the filter shows that it is extraordinarily attractive, as with careful design all component sensitivities can be kept well below 1. Also, the resistive feedback means that high-frequency feed-through (a problem in Sallen-Key and MFB filters) is probably negligible. Downside is that two opamps are needed for a 2nd-order stage (high-impedance buffer plus negative-gain stage), which I don’t see as a problem with modern high-performance opamps.
So, did anyone here work with negative gain filters?
Can anyone say anything about component-parasitic effects on this filter?
Can anyone give an opinion on opamp effects on this filter, eg, gain drop, phase shift, output impedance rise with frequency etc.?
Does anyone have other ideas or other filter topology suggestions?
A negative gain filter topology schematic is here:
Any feedback or insight is welcome, Thanks in advance,
Benta.
Benta.
