astructurale
Using computer software to generate precast and prestressed concrete beam designs is a usefull tool, but it seems that for some particular cases the design becomes too conservative.
I've run across the following when designing simple span uniformly loaded beams,
ØMn < 1.2Mcr and ØMn < 2.0Mu
This case happens at in the first 1/4 of the beam span each end under a uniform dead and live loading. I realize that the design is following the code, but does this take it a step too far. When designing a beam by hand this condition would never be found, but the software finds it becuase it evaluates the loading at smaller length intervals.
I am creating beam tables for our sales department to use, and I've found that when looking at the maximum loading on varying spans for the same cross-section & same strand pattern that as the spans shorten this becomes an issue and limits the loading capacity when using prestress alone, or it requires that developed re-bar be added near end 1/4 spans to generate the capacity requried . In my opinion this is conservative because you will never get a full uniform live load along the full length of the beam to create that exact loading scenario.
Some progams to do not even take this into account (not sure why), but it is a real design issue I've been told by the software company. I am using Concise Beam ( The first time I ran across it they said that this is a common design flaw missed when doing the calculations by hand. Is there a way to get around this. I've been doing beams for years and never had to increase my steel (or decrease my capacity) to deal with this, so it seems a little "picky" to me.
Anyone have any opinions on this or have you run across this before in your designs?
