My work requires that I do a lot of that. I add exceptions to the drawings stipulating the criteria for design or add actual loading for the EOR to confirm. The latter is often for x-bracing or misc. bracing. For flexural members, it usually based on the UDL that produces the moment for the section capacity.
I should have added that I charge by the hour, so if I redo work, I still get paid. I don't like redoing things, but it happens sometimes. Another interesting project I had a few days back. Small steel beam sections bearing on a masonry wall. the connection detail was a single headed stud welded to the end of the beam. I thought the fabricator had misread the structural drawings and added a bearing plate for the steel beam to be field welded to, for the EOR to confirm. I ask for confirmation so the EOR 'owns' the connection rather than myself.
