JMASE
- Jan 29, 2023
- 37
If precast Ts are overloaded (significantly) and their loaded deflections measured, does the failure of these Ts to rebound when unloaded imply that they have lost structural capacity? Or, is it possible that some yielding and permanent deflection has occured, but if reloaded with a smaller load could behave in a linear way? Any references to technical literature that addresses the capacity of previously overloaded Ts would be appreciated.
