Guest
Ok here's the deal.
Just a review of the setup. (BTW thanks for the ignition help earlier! EGT's are now in the low 1400 range)
Quad4 LO block, 753 head, 226 degree cams (exhaust advanced 7 degrees to reduce overlap), Garret T3-60 turbo with .48 or .43 exhaust housing from an 84 or so Ford Turbocoupe, intercooler from later year Turbocoupe (so I am told). All of this twists and turns through different sized pipes between 2.5 and 2 inch depending on location. Hey it was made with scrap parts, ok.
I have installed two thermocouples for my Omega Engineering digital thermocouple reader (reads J-type thermocouples to 1300 degrees) on my car. These are high quality devices and I know that they are accurate. They also react very quickly because the thermocouple tip is exposed to the air (not like exhaust probes)
Today before I left with the car to take a spin they both said 91F and my IAT and CLT sensors also said 91F. So everybody agrees that it is 91F outside today.
One of them is installed post-compressor on the turbo about 6 inches from the outlet of the compressor. The tip is slipped into a hose connection and turned down into the air stream (they are about 1/16 of an inch thick so they seal well). At peak temperature I am seeing about 170F. I expected up to 200F so things are better than I perhaps had thought on the efficiency of the compressor vs flow.
Ok now here is the part I don't understand.
The second thermocouple is installed in a similar manner post-intercooler near the throttle body (before it makes a 90 degree turn into the TB). During cruise times it reads about right. Somewhere between 100-110 degrees. Here's the kicker! During full boost runs the temperature drops to 65-70 degrees F! What is going on! How can I be getting better than 100% efficiency from an intercooler (it isn't possible is it!)
So what is going on? Is there a pressure drop in that hose near this location, or what else could be causing this? I really don't understand. How could the temperature be colder than the outside air temp?
There is nothing wrong with this thermocouple that I know of, but I guess I could try another one or another location.
Man I need an answer for this one.. ;^)
Rex Weatherford rex@beretta.net
92 Beretta GTZ <- SUPER INTERCOOLED
Best 1/4 ET = 14.092 @ 99.74 mph
Best 1/4 MPH = 14.115 @ 102.69 mph
