stanier
- May 20, 2001
- 2,442
I have a question related to the structure of pre-insuulated pipes and how they behave as a result of thermal strains.
I am curious to know with the foam pre insulated pipe systems what happens to the foam when the inner pipe expands greater than the outer sheath of say PE. Does the foam fracture or is it strong enough to withstand the stresses involved. Is the adhesion of the foam to the outer sheath or inner pipe strong enough to withstand the shear? If the inner pipe moves in respect of the outer sheath does it crush the foam at changes of direction? Do you have to put expansion bellows in the system?
What experience have forum members in the use of these materials?
