PPR vs COPPER for high rise building
moideen
360
The 70-story building, the existing copper pipe for domestic cold-water distribution is deteriorated and water leak issues are rampant. The pipe thickness is 1.2 mm. I recognize the selection of the pipe was wrong and the then project engineer didn’t checked properly when select the copper pipe. We here select 2.5 mm for high rise buildings. I didn’t find any PRV not placed between the main vertical pipes to withstand the gravity pressure. and the piping is laid out in two risers.we planned to retrofit with new pipe. I want to go with PPR. what is your comments on PPR VS COPPER for high rise building? which is best and recommended with high gravity pressure water circuit?
Copper shouldnt just corrode - unless there are other material as well (fitting etc) or if e.g. nails og screws frequently touch the copper.
Pr is more suspectable to water hammer - even if the design pressure is the same.
