Hi All,
I have a problem using (what I considered) a simple circuit.
I use a microcontroller that generates a PWM signal that feeds a gate of a N-channel Logic level MOSFET. When I switch the LOAD on and off (without PWM) the 5V (that powers the micro) is perfectly stable. When I use PWM to switch the load the power changes as you can see in the attached picture. The micro of course goes crazy from time to time.
-The load is a LED board powered at 12V 25 groups of 5 leds with current limiting resistors.
- The 12 V are provided by a bench power supply.
- The 5V are regulated on board using a 7805.
- No gate resistors
- I have all decoupling caps in VCC /GND
- Changing PWM frequency as no effect.
Can some one help please?
Thanks in advance.
- No gate resistors
Thanks in advance.
