IronRingReno
I am putting a new 5 pin DIN plug on a switching power supply for a KVM Switch. The label on the power supply provides the following information.
Pin 1: Ground
Pin 2: Common
Pin 3: +5VDC
Pin 4: -5VDC
Pin 5: +12VDC
With my voltmeter I can find the +5VDC, -5VDC and +12VDC voltages. They are on colored wires.
However, both Ground and Common appear to be black wires.
Is there a problem is they get switched when attached to the new 5 pin DIN plug?
Pin 1: Ground
Pin 2: Common
Pin 3: +5VDC
Pin 4: -5VDC
Pin 5: +12VDC
