Hello everyone,
Totally new.
I have a test rig that operates on 28V and powers (10) electronic components. Typically when we run the system we used the power supply that wil be used on the final system and powers everything up with no problem.
My problem is when I power the test rig externally using a power supply set to 28V (voltage limit at 28V) and turn the PS output ON I botice the voltage on that PS go down to 5V and current reaches a limit set to 1A.
Do I need to raise the current limit on the ext.PS to ensure I have enough power going to the system to power all (10) units? IS what I described called "loading down the PS?"
Thanks,
Totally new.
Thanks,
