The requirement would be almost zero, however the output might be close to maximum, depending on pump speed at maximum output, engine speed and pump drive ratio.
I think you need maximum pump output, not pump requirement.
Maximum load is likely to be when trying to steer past full lock or when doing very rapid steering action at higher engine speeds, such as slalom course racing.
The one car I had that was inclined to fail belts always failed when applying sudden correction for oversteer when cornering very aggressively in low gear at near red line rpm.
I won't mention brand names, but Greg will probably understand from the term 1988 EA. It may well be he who fixed the problem in later models.
