Please refer to the attached .pdf sketch.
I have a component of mass 7.5 (74730N) Tonne mounted in a frame.
The frame is connected to a shaft mounted on bearings.
The shaft carries a large sprocket which is driven by a transmission chain via a small sprocket connected to the motor.
The component/shaft is required to rotate at 0.6 rpm (0.01rps).
My question is, what is the power requirement of the motor?
Although this is not my forte, I have made an attempt and have come up with 4.123Kw.
