I have an ongoing discussion with several people as to how the power output on a generator is changed. The generator is connected to a steam turbine and is rated at 450 MW. Some say that by changing the excitation current you create a larger or smaller magnetic field, therefore changing generator power output. Isn't changing excitation current the primary means for generator voltage regulation and MVARS control not total power output? Others have suggested that by adding more steam flow you create more torque on the generator rotor therby increasing power output. I'm not sure how this would even be possible. Maybe all the different ideas just have me confused and I'm overlooking a simple answer. Any help is appreciated.
