1. Please for suggestion on how to make a power copy in V5R16 SP5 without gaps (see image).
When instantiated I want to be asked to select only the FACE and POINT.
I have made it using three holes (simple, countersunk, threaded) but I was forced to put small gaps (0.01 mm).
2. Above mentioned PowerCopy can be instantiated when I select the face of pad,
but I receive error when I select the face which is the result of some boolean operation.
What could be the problem?
