Power Calculation of Hydraulic Rotators 3
Startto
16
What is the formula to calculate Power(Kw) and Rpm of a hydraulic rotator (Vane model) from Torque 900 Nm, Displacement 330cm3, flow rate 14 L/min, volumetric efficiency is 0.9?
@EngDesServices
Hello Friend,
Thank you so much for your kind reply.
But I see some faults in the formula when tested with my model.
When I tested the rotator with flow of 14l/min, RPM was 42.
So Power (KW)= (900*41)/9.548
= 3864.68 KW
= 5178.67 HP.
I think the constant should be 9554 instead of 9.548?
@hydtools
Hello friend,
Thank you so much.
As per your formula,
RPM = 14/0.33
= 42.42 RPM
Stays closer to the practical result of 41 rotations.
Do you have any Idea how to find power from the values provided in my question?
@hydtools,
Hello Friend,
I understand the concept behind 9.9453
But look the answer 3864.68 KW.
I am sure this power is not technically possible.
Please correct me if I am wrong
Hey Startto,
I edited my post to reflect Watts as opposed to kW, guess I wasn't paying enough attention the first time around. Sorry about that.
Power is simply the work done per unit of time or P = W/dt.
A watt is 1 joule per second which is equivalent to 1 NM/S.
So to get power in Watts, you are going to want to find out the amount of work performed in 1 second.
Using HydTools equation for RPM with your input values of 14L/min and 330mL displacement per rev and 0.9 volumetric efficiency gives roughly 38RPM.
To use RPM in the final equation, you need to convert it to angular velocity - which is where the 2*pi/60, or 9.549 in the formula comes from.
Putting it all together leads to: 900nm * 38RPM / 9.549 = 3,581.5 Watts or 3.58 kW or 4.8 hp.
Hope that helps.
Michael Hall, PE (TX) PMP - President
Engineering Design Services LLC
@EngDesServies,
Hii friend,
There is no need to be sorry, It happens.
But really thank you , yes it does helps.
