I need help, please.
I have an application with a rotating cylinder in which material is tumbled for processing purposes. The following quantities are known although I have need of generic formulas in the future as these are variables between system applications.
Known Quantities:
Vessel mass (empty):146,000 lbs.
Inside diameter:11’-9”
Outside diameter:11’-10”
Weight of material:80,000 tons based on 32 lbs/ft3 bulk material density
Drive arrangement:1800 rpm electric motor coupled to gear reducer (55.2:1 gear reduction) driving steel wheel, 24” in diameter.
Number of drives
4) each. The (4) steel wheels drive and cradle the vessel through (2) circumferentially mounted, 14’-1” diameter driven rings.
Time to accelerate:approx. 10 seconds
Full speed rpm: 6 rpm
My Methodology:
1. Calculate moment of inertia I of vessel (neglecting everything else) using:
m•(di2 + do2)/8 = 5,052,310 lbs-ft2
2. Calculate average angular ? acceleration using:
6 rpm • 2•?/(60 sec/min•10 sec)= 0.0628 rad/sec2
3. Calculate total torque required to accelerate from:
T = I•? = 317,285 lbs-ft
4. Calculate torque required from gear reducer output. If 317,285 lbs-ft is required at 7.04’ (radius of driven ring), 45,058 lbs. of force must be developed at the drive wheel. Since the radius of the drive wheel is 1’, the torque developed at the output of the gear reducer must be:
45,058 lbs. x 1’ lever arm/4 drives =11,264.5 lbs-ft per drive
5. Determine torque input to the gear reducer. Since the gear reduction ratio is 55.2:1:
11,264 lbs-ft/55.2 = 204 lbs-ft motor torque
6. Determine motor HP rating from the relationship:
T•rpm/5252 = 69.9 HP per drive
Conclusion:
Based on my calculations, each motor will need to develop approx. 204 lb-ft of torque to accelerate the vessel. I realize that the motor could be sized based on breakdown torque, not using the above simple HP=T•rpm/5252 relationship which yields approx. 69.9 HP to be developed by each motor. If breakdown torque is approximately 230% of full speed torque, (4) 30 HP motors would suffice accounting for a 1.15 service factor. I just need verification that my methodology is valid and that my figures are reasonable. Also, I realize the above does not account for the material to be processed in the vessel. I must also take this into account and would very much appreciate any help you can provide along these lines as well.
Known Quantities:
Number of drives
My Methodology:
Conclusion:
