I am trying to find some theoretical basis to calculate the maximum power that could be required to drive a vibrator of the eccentric mass type. The applications I have in mind are mineral aggregate screening and feeding equipment.
There are recommendations from many sources on the power required for a particular piece of equipment with particular loads. It seems that these power requirements have been derived from experience and I have not been able to find the theory.
The relation between speed of rotation of the eccentric mass, its mass, its eccentricity and the resulting forces is well established in traditional formulae. From these one can calculate the resulting accelerations on the equipment to which it is attached.
My question relates to the power absorbed in this process. As I see it, there are 2 limiting cases, and the desired value will be somewhere between.
Case 1) The rotating shaft with eccentric mass is mounted on an infinitely heavy structure. The centre of the shaft remains in one place and the eccentric mass centre orbits around it. Work done = 0.
Case 2) ) The rotating shaft with eccentric mass is mounted on an weightless structure. The centre of the shaft performs a circular orbit and the eccentric mass centre remains in one position. Work done = 0.
Does anyone have a formula to calculate the intermediate real-life case of power absorbed with known solid structure mass ?
More importantly, does anyone have a formula to calculate the maximum theoretical power that could be absorbed in driving the eccentric shaft when the the structure on which it is mounted contains energy absorbing (damping, loose) material at the optimim mass to absorb the greatest power ?
Richard Beneke
Richard Beneke
