I am not EE and need to understand this issue a bit better (from the process energy use optimization perspective).
When an AC Induction motor operates under partial load conditions, the Power Factor and the motor Efficiency go down. There are a number of ways to resolve this issue but any of them will have to be justified on the basis of cost/benefit issues.
The QUESTION is: what is the potential energy savings on the motor alone (other opportunities related to the load, the process etc. are considerate separately) ?? Is it just that gained by improving its efficiency up to rated values again (e.g. to full load condition) ??
As an example, take the case of a motor driving a pump.
Peak demand requires that the motor be of 100 hp.
However, the pump operates a significant amount of time at 50 or 60 % of the peak condition.
The Current (amps reading) for the motor go down from its full load condition. So the Power Factor goes down.
From tables (provided by the manufacturer) the Efficiency also goes down (e.g. the portion of Electric Energy fed to the Motor that gets converted to shaft power is smaller and the rest is wasted).
The potential savings in Electric Energy from resolving this issue are only those corresponding to the lost Efficiency ??
(again, I am looking at the motor only. Other possible savings like pressure drops, flow re-circulations etc are evaluated separately)
Thank you all for your time and attention.
