postbuilder machine axis
berri
102
Hi guys,
I want to know, how can I customize machines axis on postbuilder. For 3 axis horizontal and vertical milling center and 4 axis milling centers too.
How can I change machine axis, from horizontal +Z to vertical +Z and vertical+z to horizontal +Z
See you soon, thanks.
Once you have created a post, you cannot "change" the kinematics of the post anymore. Once it's set, it's set.
You can however, create a new post, with new kinematics, using another post as a controller.
What this will do is bring in all customization that you have done to a new machine type.
Search the help file for "Changing Postprocessor Kinematics"
Also, see attached picture
Hope this helps,
JAY
 http://files.engineering.com/getfile.aspx?folder=39badd58-55e5-4c59-b4ba-76be9f335fd6&file=new-post.JPG
Thanks Jay,
I see, I tried to change the done post...
I was wrong.
See you.
