post processor for sinumeric 840d
  • Thread starter Thread starter nadeem_asghar
  • Start date Start date
N
nadeem_asghar
Guest
I am making a post processor for sinumeric 840d in pro engineer wf3. the problem is that when i try to put sinumeric 840d cycles and save it, it didnot save it, and the cycles format are not coming in the tap file. plz give suggestions
Make sure the folder you are trying to save it to is not write-protected.
If it is write protected it does not give you any indication that it is not saved.
Its a problem I had a while ago.
Make sure the folder you are saving it to and the folder you are loading the post from is also the same. Check that GPOSTPP_DIR is set to the correct folder.
thanks Jabo. i have seen that other changes are going on in it and also have saved but the problem is coming only with sinumeric 840d cycles ( reaming,boring,drilling etc) this is making problem.
Hi Nadeem
It is better that you must upload the file, so i can have a look, also let me know weather you are palaying with gpost areaor withFIL programming.
I
Dejan007
how much?
How much what? I dont know what you mean?
