joachimsarkimaki
I have exported the clsf from my operations, modified it (with feedrate optimazations) and then imported it back into NX again. After that, when post-processing, my added custom UDE:S won't be outputted (only the standard ones that's installed with NX). The pp just complaints on "unidentified text".
I have added events and templates for my custom UDE:s inside clsf.tcl and /.def to output the correct syntax inside cls when exporting. Somehow I need NX to interpret that syntax and give my UDE-variable this value when post-processing. How can I do it?
I mean, it must be possible since nx does it with its "pre-installed" UDE:s. Hopefully someone of you guys have faced this problem before.
Joachim Särkimäki
Joachim Särkimäki
