MrEngineerUS
- Apr 9, 2013
- 46
I was tasked with designing a concrete wall that has a bench projecting out from the side of it. They would like the face of the bench to extend to the ground. Essentially, an 18"x18" cross section of concrete that projects from the side of the wall face that people will sit on. The concern is that frost heave would act on the bench but not the wall (as the wall footing extends below to the frost line depth) and cause cracking.
Is it likely this would this actually occur or is this concern unwarranted? I have a hard time believing that pressure on the bottom of the bench from frost heave would be so great as to cause cracking. The bench protrudes 18" from the face of the concrete wall.
