WittyNameHere
Hey guys,
I'm designing a system and I have to use two separate pressure sensors hooked up to the same line. The first is going to be a 500psi pressure transducer for a low pressure test (250psi) and the second is a 20k pressure transducer for the high pressure testing (10-15k). When I start the high pressure test I need to be able to have a valve or something that automatically shuts closed in front of the smaller transducer when the pressure becomes too high (say, 500psi) so that the transducer doesn't blow. This is also why it has to be a positive shut off valve.
I haven't found anything so far. I'm thinking it would basically be like a pressure relief valve but instead of releasing the pressure it just closes shut.
*Edit, sorry I forgot to mention this in a hydraulic system
Thanks in advance for any help.
