mjmarkey1979
- Jul 27, 2010
- 16
I'm currently dusting off my 10 year old power knowledge, and more specifically unbalanced fault analysis which hasn't been used for a while as I've been in the building services game for the last 5 years (so ohms law and the volt drop equations was about all you had to remember).
I remember that the majority of the time positive and negative sequence components are usually equal but with their vectors shifted and that Igf = 3VLN / (Zo + Z1 + Z2 + ZG). Where Zg is the impedance of the ground return path including any arcing (if that's applicable of course).
If you know the earth fault current from a site report and the fault level of the grid supply point of say 2500 MVA, is it possible to derive from that the Zo + Z1 + Z2 components based on the assumption that Z1 = Z2 and from the grid infeed impedance (Zs) say 0.04 based on a 100MVA base.
Sorry gents, but I could really do with a sanity check and more insight into something I don't normally do everyday, it's a new position and making a good impression with this crowd and me stressing on this stalling on this is not giving me the clarity I need.
Thanks in advance.
Thanks in advance.
