I'm designing a filtration and oil transfer skid for gear oil. The reservoir is located too far from the main lube skid that it would reduce the pump performance due to the long suction line. To correct for this I will install a transfer pump adjacent to the reservoir which will pump the oil over to the main lube skid.
Therefore, I will have (2) positive displacement pumps in series. I'm wondering if I can select two identical pumps and run them in series? The transfer pump will operate at approximately 4-bar and the lube pump will operate at 8-bar.
The pump manufacturer's curves show that at 4-bar the pump will discharge 354 L/min and at 8 bar it will discharge 347 L/min due to loss of efficiency at higher discharge pressures. Will I run into any problems with an arrangement like this? The transfer pump will have an overflow relief back to tank but I don't suspect it will see much flow.
I've included a very basic schematic attached.
Or, should I select a larger displacement pump for the transfer portion so that I am guaranteed sufficient flow to the lube pump?
I cannot find any information online about recommendations or tips on this type of an arrangement.
Thank you.
Thank you.
