I typically use peristalitic pumps to pump thick sand slurry (60 to 75% solids weight for weight) with a yield stress of up to 120 pa. My flow rate requirements are 1 to 10 litres a second. I typically use the Bredel SPX range, which work well. However, the pulsation in the flow is not ideal. I need a positive displacement pump that can maintain a perfectly smooth continuous laminar flow from the end of the discharge pipe (i.e no variation in the projection of the slurry as it flows from the end of the pipe). I am thinking to buy a screw pump and mount it below my delivery tank which holds 4 m3 of slurry agitated with a mixer. However, i have no experience with these types of pumps and i'm not sure it can deliver a perfectly smooth flow. I also have to fix the flow rates so an inline flow meter would have to be used to set the pump speed to deliver the specified flow rate.
The distance I am pumping is 10m from the mixer tank to the discharge point. It can be increased slightly to help smooth the flow rate if necessary.
I'd appreciate any advice on other options to smooth the flow using any type of positive displacement pump. I've been banging my head against a wall for almost two years now.
Many thanks
Many thanks
