Positioned Sketch
Santa123
80
Hej,
What is wrong with my code?
Code:
Sub CATMain()
Dim Component As Part
Dim MyDocument As Document
Set MyDocument = CATIA.Documents.Add("Part")
Set Component = MyDocument.Part
Dim part1 As CATBaseDispatch
Set part1 = MyDocument.GetItem("Part1")
part_name = InputBox("Part Name","")
part1.PartNumber = part_name
Dim MySketches As Sketches
Set MySketches = Component.MainBody.Sketches
Dim HAxis, VAxis As Line2D
Set HAxis = Sketch.AbsoluteAxis.HorizontalReference
Set VAxis = Sketch.AbsoluteAxis.VerticalReference
Dim OriginElement, MyPlane
Set OriginElement = Component.OriginElements
Set MyPlane = OriginElement.PlaneYZ
Dim Sketch As Sketch
Set Sketch = MySketches.Add (MyPlane)
'Dim Wzk As Factory2D
'Set Wzk = Sketch.OpenEdition
'Sketch.CloseEdition
Component.Update
End Sub
Respect
Santa
can't create an empty sketch... you need geometry in your sketch
Eric N.
still something wrong
Code:
Sub CATMain()
AXIS2D.HorizontalReference As Line2D
AXIS2D.Origin As Point2D
AXIS2D.VerticalReference As Line2D
Dim Line As Line2D
Set Line = Wzk.CreateLine (50,50,50,-50)
Sketch.CloseEdition
Component.Update
End Sub
Santa123
Knowing which line you are getting the error on would be helpful.
Your problem is likely here because the 'Part1' is going to be incremented the 2nd time you create a CATPart.
The Part Number property is a child of the 'Product' object which can be retrieved from the PartDocument object.
--Doug
Where does the macro fail?
You already have:
Why do you need part1? Why not just use Component?
As Doug mentioned you can use MyDocument.Product.PartNumber = part_name
If you search the help document for "CAAInfGettingStarted.CATScript" you will get a macro that creates a sketch that defines the horizontal and vertical axis.
@Santa123
The title of your thread is "Positioned Sketch". To the best of my knowledge you cannot create a "positioned sketch" using VBA. All sketches created using VBA are "sliding" and the user would have to change them after the script creates the sketch by defining the positioning. For a sliding sketch the only thing you can specify is the plane on which it will be created. Or in your case:
Code:
Drew Mumaw
hej drewmumaw,
Thanks a lot. My plan was to create a template of Part(just to save some time, creating new Part), but now I don't think it's a good idea. What do You think?
Respect
Santa
@Santa123
Many companies simply use "start parts" to achieve what your after. For example, they have a "start part" (also called a "template" part) that already has certain axis systems and properly named geometrical sets in it. It also might have a solid cavity/core structure already set up for solid modeling. In the case of a sheet metal "start part" it would already have the proper bend radius and sheet metal thickness in accordance with company standards. Any time a new user creates a part they simply choose "new from" rather than File > New.
Drew Mumaw
