Jashe,
I agree with John, perpendicularity would be more appropriate because all position is doing in the case of the top hole datum is creating a tolerance zone perpendicular to [A] and not actually locating it to another feature.
That being said, the way your datum structure is set up suggests that your top hole (datum ) is more important that the bottom hole (datum [C]) due to datum precedence - is that truly the case? My guess is probably not and maybe you should consider holding them together as a 2x pattern with position and the whole pattern should be datum .
