ptruitt
- Nov 13, 2007
- 233
I am interested in using statistical tolerancing on upcoming projects, but I am not sure what the Cpk will be based on if the 'size' nominal is not the same as the 'form' nominal if I use bonus tolerance. Is there a formula that averages the two or weighs them? Is it correct to say that 'form' is the area between the Virtual and Resultant conditions?
Since more and more software is using the CAD model for machining and inspection, should nominal CAD geometry be established at the nominal form geometry or at the nominal size geometry when using the MMC modifier on holes and similar features such as slots?
As others have said on another thread, 'position' information is often not reported on inspection reports. But if it is, is there a yes/no indication that the 'size' measured was allowed given the measured 'position'?
I prefer using profile call-outs whenever possible to keep my nominal size and form the same, but some of my suppliers are not comfortable with 'profile', so I need to figure out how MMC works with statistical tolerancing.
Peter Truitt
Minnesota
Peter Truitt
Minnesota
