rafcu
Petroleum
- Aug 12, 2003
- 16
I am looking for calculating the overall polytropic efficiency for of two compressors in parallel.
I have the performance map from the supplier for both compressors with the polytropic head depending on the flow rate; the speed and the efficiency are also represented.
But for two different speeds with the compressor running in parallel, I wonder how calculated the overall efficiency if I have for example 78% for one compressor and 82% for second one. What is the overall efficiency?
regards,
Rafcu
regards,
Rafcu
