How to find the width of an existing polyline?
Pedit command give has one switch "W" it allows to set a new width to a polyline
but does not show the current width before setting new width.
Select the item and go to properties, there it is found.
Select the item and ask a list of it. (_list is the command)
Select the item and ask info of it. (info is the command)
Good luck
