StructuralEIT,
My point was that young engineers nowadays usually have some CAD experience because hand drafting isn't widely used any longer. How much that experience helps them in their day-to-day engineering work would depend on how well they learned and understand the process of DESIGN, not just drawing. Simply knowing how to draw lines in CAD won't necessarily give you the experience you need in learning how to design correctly. You can be an expert at CAD and know all the shortcuts and be lightning-fast, but if you don't understand the basics of a good design, just knowing how to draw in CAD won't make you a good designer.
But I think the reason a lot of companies want you proficient in CAD is two-fold: (1) you have the technical ability to understand a cad drawing when it is sent to you; how to open it, manipulate it, turn layers on and off, incorporate it into your work, plot it, etc. -- especially in smaller companies without a dedicated CAD staff, and (2) it shows you PROBABLY have some DESIGN experience. If you took classes to learn AutoCAD or another program, you likely have some design sense, or are on your way to acquiring it, and hopefully it's good sense and not non-sense. You may not actually even use AutoCAD in the position you are applying for, but if you have the ability to use it, it adds to your overall "value" to the company. (And they can always make you a CAD monkey if things get slow...)
I'm at an age where I learned on a drafting board through middle and high school, and CAD was just starting when I hit my college years. I used a drafting board all through my classes for my architecture degree, but used more CAD by the time I went for my CE degree. I really value the hand-drafting experience, as much as I value knowing AutoCAD, and I'm fairly proficient at both. Just being able to draw something in CAD doesn't mean it will work in the real world.
I get plans across my desk nearly every day that aren't worth the paper they are printed on. HVAC running OUTSIDE the roof structure, incorrect details referencing other incorrect or even missing details, etc. Dimensions that don't actually go to anything, that's always nice. Whether these were drawn by an engineer with poor CAD skills, or a CAD tech with poor engineering skills, I'll never know - but either way, it reflects poorly on that company, and no owner or manager wants people to think their company isn't the best.
Personally, I wouldn't care whether you are proficient in CAD and can do your own sketches, or if you hand sketch and give it to a CAD tech, as long as your design really WORKS in the real world. But, if I were a boss looking to hire, and I had the choice between someone who was proficient in CAD or someone who had no experience with it, all other factors equal, I'd go with the CAD experience.
