JStructsteel
- Aug 22, 2002
- 1,461
What are your guys thoughts on a pole barn garage door beam? Its a 18' span, the builder wants to split the beam and have it on each face of the column, bolted thru. Do you feel the load will be shared? Its a 48' span across. Trusses at 4'-0" o.c. I was going to make them bolt/nail the beams together and use a hanger of the side of the column.
