IntolerantofApathy
- Jun 1, 2016
- 1
Does anyone know why polar equivalents to Ordinate Dimensioning is neither described by 14.5, nor included in common solids modeling drafting packages? To clarify my question, please consider scenarios where a design requires multiple angular dimensions. On a drawing, situations like this occupy a lot of space on the page because multiple dims create successive, concentric arcs. These can become particularly space wasting when angles exceed 90°.
In the world of rectangular coordinates, "busy" drawings appear less cluttered through the use of ordinate dimensioning. Moreover, I've never seen a limitation for using GD&T in conjunction with ordinate dims (features controlled by GD&T can use basic (but ordinate) dims as long as datums are established and feature control symbols accompany them). And the CAD packages I've used (Creo/Pro/E, SolidWorks, and Siemens NX) enable ordinate dimensioning. On the other hand, I don't believe such capabilities are integrated for polar dimensioning within any CAD packages I've seen.
Obviously, there are designs that are best conveyed using polar dimensioning. And, since the accuracy of angular dims gets progressively worse with +/- dimensioning (for example, a +/- 0.5° angular tolerance will generate twice the positional accuracy when a feature's location from the center of the polar array is doubled). In my opinion, this goes away with GD&T because the perfect location can be conveyed by basic dims and true position controls the accuracy. And, if the polar equivalent to ordinate dimensioning were available, the nuisance of successive arcs eating up the space on the page is lessened.
Thanks, in advance, for any comments or suggestions. (My apologies, by the way, if this topic has been asked in the past. I did a search but didn't see it.)
