Hi folks.
I am trying to build a project that uses compressed air to propel objects through 1 inch tubing. And the object has to travel the length of the pipe system and then return to the beginning. The problem I'm trying to solve is how to have the object stop at the ends of the run in a controlled mannor. Object can not smash into the valves at the end of the runs.
Any advice on how to achieve this would be appreciated.
