Am designing an aluminium docking structure to be used by mechanics during aircraft maintenance. As they use compressed air for their pneumatic drills, one of the design requirements is to install distribution piping on the structure, which can later be connected to the main pipes (from the compressor) at the time of use.
Can someone advise me on what is the best material to use for this pipe (PVC, Steel or any other), considering that weight has to be minimal as the dock has to be pushed around the aircraft manually.
