PMI visibility in drafting
buyo
Aerospace
GB
Problem description:
Unable to show PMI made from sketch in the drafting module in parent item.
Other PMI made manualy are shown (PMI Assembly Filters).
In master model (drafting module), PMI made from sketch and PMI made manualy are visible.
This problem occurs only in parent item. In master model everything is ok.
Check if the PMI information is also in the ref set MODEL
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Hi Ronald,
I don't understand you answer because it was not possible to add PMI on the Ref Set Model. I have opened a call on GTAC for that.
I use the following process:
Use Reference Set "Entire Part"
then
the sketch should be visible in the master model !!!
Didier Psaltopoulos
PMI is view dependent. As such, it would not show up in reference sets.
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
Thank you all,
"reference set" solved the problem.
By default is "entire part" but the PMI from sketch was not active.
You have to select them in the "entire part" reference set.
That will do the job.
OK, but your example is so simple
In fact, you don't add only PMI to your ref set because they are not selectable. You are obliged to select the whole sketch
I found a trick to blank the sketch in drafting and what about you ?
Didier Psaltopoulos
Because you are talking about ref set I assume you work with master model. Then PMI is in model part and you need to show PMI in DWG model.
Firs make sure your component is fully loaded (If you open drawing file directly. If you open model and then drawing it will be loaded)
Then when you place view, go to view settings and find PMI tab. In PMI tab click on drop down menu and select From Model View. This should be enough to see PMI that you get in that view without need to use ref.sets.
_____________________________
Enjoy your work and have fun!
Hi Ivan,
I don't agree with you
I know this process, but I you don't use Entire Part, you will have the following message:
Didier Psaltopoulos
Then you have to set OBJECTS that PMI is linked to to model ref set. PMI is not part of ref set, but they are connected to model so if you removed parts of model form Model ref set, that is why you can't see PMI. PMI works without ref.set if all objects that have PMI are in model ref set.
Hi Ivan,
Could you send a screenshot to explain where you do this settings ?
thanks in advance
Didier Psaltopoulos
If you have model with all objects with PMI in model reference set
Then drawing looks like this
2018-03-05_10_41_39-NX_10_-_Drafting_-_1JNL100440-261_00-PMI_example_specification__1JNL100440-261_kvm8yu.jpg
But if you remove one solid body from model reference set
2018-03-05_10_42_37-NX_10_-_Drafting_-_1JNL100440-261_00-PMI_example_Modified_gwtzex.jpg
Then you get that error message (either on update or in your case on view placeing)
2018-03-05_10_42_56-NX_10_-_Drafting_-_1JNL100440-261_00-PMI_example_specification__1JNL100440-261_qb1zjy.jpg
So go to reference sets in your model, and make sure that all objects that have PMI conneted to them are in model reference set.
After thinking a little, I think that you have sketch that is stand alone, so it does not make body, but it have PMI connected to it (bodies are by default set in Model refeernce set, but sketches are not). You should add that sketch to Model reference set, so you do not have to use Entire Part.
Hi Ivan,
You are right, I am taking about standalone sketch. And in this case I know the process and I should use ref set or entire part.
But I am obliged to hide the sketch in the Master model to avoid see it in the drafting :( Other idea ?
Didier Psaltopoulos
