JStructsteel
- Aug 22, 2002
- 1,454
Hi, I looked at a roof yesterday that is experiencing some failure of the plywood, shingles etc. Its a gable roof, with shingles and plywood over steel joists. there seems to be some warpage, and undulations in the roof. I could only see the roof from the inside, there is 1x nailers on the joists, and then plywood nailed to that, and shingles. The plywood is spanning 48", so I am thinking thats the problem. Some other issues I think is the attachement of the nailer to the joist, it appears to be powder driven fastners, and then plywood nailed to that. I am seeing some pull up of the nailer, and thinking that wind suction over the gable could be causing some failure too.
That all said, and without knowing the span rating of the plywood, does anyone think 48" is too much for the plyood to span with shingles?
