PlugIn Error When Trying To Mesh 1
pmbov
I need help please. I am running ANSYS 12.1. I have created the geometry in DM. When I go to mesh the geometry I get 3 errors: "unable to attach geometry file" , "PlugIn error: No valid bodies found" , "PlugIn error: Attached failed"
Can anyone help please...
I have tried other suggestions from other older forums and nothing has worked so far.
Can you post a couple of pictures of what you're seeing? It seems like there's a problem with the geometry that you created.
I though the same thing. So I did it again with just a rectangle. Same result.
Has it ever worked before? Can you post a couple of pictures of what you're seeing?
I can't post any pictures, because I have used a work around (mesh the part in v12.0 and use v12.1 to analyze), and it works good so far. However, I will not have 12.0 installed much longer, so trying to get the fix now.
