Plugging-in a Portal Script into the ODB session
Cansand
CA
hello
I am trying to Plug-in one of the scripts already existing (and ready for use) in Process Automation Portal .First, I open my ODB file (which needs to be communicated with the script in the Portal), then in ODB I went to Plug-in then ABAQUS then Process Automation Portal (where I located my desired script) but I do not know further how to bring it to my ODB session.
Did anybody have to Plug-in a script from the Protal before. Please advice
You need to download the plugin file (probably a zip archive) first. Then you extract the plugin to your "abaqus_plugins" directory. You may need to create this directory - do so in your working directory:
I.e.
If your working (startup) diretcory is
d:/users/abc/abq_work
Then create:
d:/users/abc/abq_work/abaqus_plugins/
Copy the zip file to this new directory.
Right click - "extract to here"
Start /CAE.
Brep
Thanks for help. Can one do that in some other way if one
has got the text script file (file.py)
Thanks again
