our thermal power plant has lp bypass valve, normal closed,
so it has normal warming line which has plug resistance orifice. it is supposed 36kg/cm^2(pressure)540deegreC(temperature) upstream of the orifice.
then, what are the changes in temperature, pressure, flow?
pipe is 50mm dia, length is 50m, downstream to condenser.
I want to learn the charaterist of the plug resistance orifice
