Plotting Logarithmic Contours for Stress 2
mmmbordo643
New member
Feb 24, 2006
31
hello,
I am trying to save a stress contour animation using the same limits for each frame. However, the range of stresses is so large that nothing appears for most of the frames when I use the same limits. Is there a way to plot the scale in log form so that the contours are apparent for each frame.
thanks,
Chris
In viewer 6.6.1 there is an option for contours to give a log interval rather than a uniform interval
corus
what if i do not have version 6.6-1...currently 6.5-3
If the maximum stress is confined to a small region it might be better to have uniform contour intervals but select the maximum contour to be much smaller than the absolute maximum produced by the model. Stresses above this artifical maximum value will appear grey but you should see more colour in the overall picture. A similar thing can be done with the minimum contour limit.
corus
For those that haven't upgraded to 6.6 yet... try this:
>>> from abaqus import session
>>> from abaqusConstants import *
>>> vp = session.viewports[session.currentViewportName]
>>> vp.odbDisplay.contourOptions.setValues(intervalType=LOG)
(... intervalType=UNIFORM is the other option)
