My company does not have nCode. our ansys license is very limited with regard to fatigue. We get outputs from ansys simulations that are input into our in-house software for post processing. The results are fatigue lives and damage.
It can produce life and damage results at all selected nodes in a txt or CSV file. I would like to find a way to plot the result in ansys on to the source mesh. I have tried using a "csvplot" ACT extension by CAE, and it works in some cases but produces unacceptable errors in others. Is there any APDL command objects that will read a txt file assign a value to each node for contour plotting? Even if the contour was an apdl image. I'm using v18.2 but can upgrade to 19.
