PLOTTING A WINDOW 1
dj4244
48
I know ploting a window in a model works fine wysiwyg, but how do you plot a window in a drawing????
David A. Johnson
Thunder Systems Inc.
Corona, CA
File\Print\ Select "Selection" under the Print Range area. Located in the lower left hand side of the Print menu.
Scott Baugh, CSWP [borg2]
faq731-376
File, Print. Click on the "Selection" radio button in the Print range section at the lower LH corner of the Print dialog. You will see a gray box at the lower LH of the drawing. You can drag the selection box to suit. There will also be a dialog allowing you to change the size of this selection box. The contents of the box will print.
Sorry I have no selection radio button or a print range area in my pop up for the printer! Using a HP laser printer capable of 11x17 prints.
David A. Johnson
Corona, CA
If you don't see this then you have a problem with your SW and you should call your VAR. This has been here since SW came out or as long as I can remember. It doesn't matter what printer you are using. These menu's come standard in SW.
When you click File\Print - what do you see? You should see a menu that contains this -See Below
The "selection" is circled. Once you highlight that you click OK and then you will get the window.
faq731-376
I see it now. It was just so different from what I am used to I missed the window/box. It sort of blended in with the drawing. many thanx
David A. Johnson
Corona, CA
