ploting area ia out of paper!
FRED70
5
i'm trying to plot my drawings which are drafted on B size paper in autocad and our ploter is D size, in plotting dialog box i choose D paper size and i check "scale to fit" box then i define corners of the drawing as the window, in preview everything is ok but after plot i see that some parts os the drawing are out of the paper.could anybody help me please?
thank you all
Hi FRED70,
The first thing that I would check is the offsets from 0,0 origin in the plotting dialog box. It is usually in the media orientation settings. you may need to adjust your X, Y, or X & Y settings to "slide" your drawing back onto the paper.
Hope this helps,
Paul
dear PLB
thanks for your answer,i check origin offset but problem is somwhere else.i don't know if something might be wrong with plotter configuration? does anybody have any tips?
thank you again
You may want to go to the plotter manager in ACAD for this printer and Modify the paper sizes to not create any margins for the different paper sizes. Also check that your metric and english settings are in sync. Just a couple of things to check for.
You may want to download the latest window Drivers, again. And make sure you have the right ones. NT versus Win2000 is a big deal.
We recently upgraded here and it caused a problem here until we re-installed the new drivers.
Hope that helps.
Rich
