At my company we use an autolisp routine called ddts, it will show the file location, filename, date, and time. It also saves the file in the current directory.If you want to try using it go ahead and paste the following lisp routine in notepad, and save it as ddts.lsp
Hope this helps,
Don
;;; ***** DDTS.LSP *****
;;; Places Drawing name, Date and Time Stamp at lower left corner of drawing
(defun c
DTS (/ CE AP CL DP DN CD MX HR MN LM LX DX TH DS MO YR TS TM UN TX OSM)
(setq OSM (getvar "OSMODE"))
(setvar "OSMODE" 0)
(setq CE (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(setq TS (getvar "TEXTSIZE"))
(setq AP "AM"
CL (getvar "CLAYER")
DP (getvar "DWGPREFIX")
DN (getvar "DWGNAME")
UN (GETENV "U")
CD (rtos (getvar "CDATE") 2 4)
MX (atoi (substr CD 5 2))
HR (atoi (substr CD 10 2))
MN (substr CD 12 2)
LM (getvar "LIMMIN")
LX (getvar "LIMMAX")
DX (distance LM LX)
TH (/ DX 552)
DS (polar LM (/ pi 5) (/ DX 60))
;;;DS (polar LM (/ pi 6) (/ DX 100)) [orig]
MO (nth MX '(nil "JAN" "FEB" "MAR" "APR" "MAY" "JUN"
"JUL" "AUG" "SEP" "OCT" "NOV" "DEC"))
(if (>= HR 12) (setq AP "PM"))
(if (>= HR 13) (setq HR (itoa (- HR 12))) (setq HR (itoa HR)))
(setq YR (strcat "DATE: " MO " " (substr CD 7 2) ", " (substr CD 1 4)))
(setq TM (strcat "DWG. NAME: " DP "" DN " " YR " TIME: " HR ":" MN " " AP))
(command ".LAYER" "T" "DATESTAMP" "")
(command ".LAYER" "N" "DATESTAMP" "C" "7" "DATESTAMP" "S" "DATESTAMP" "")
(setq TX (ssget "X" (list (cons 8 "DATESTAMP"))))
(command ".ERASE" TX ""
".STYLE" "STANDARD" "" "0" "1" "0" "N" "N" "N"
".TEXT" DS TH "0" TM
".LAYER" "S" CL ""
(setvar "CMDECHO" CE)
(setvar "TEXTSIZE" TS)
(print)
(print TM)
(setvar "OSMODE" OSM)
(command "qsave")
(princ)
