Plot files
civeng80
AU
How does one view a plot file ? Tried method using windows but does not work. Any other way without buying specialized software? or print file as PDF ? If so any ideas as to which is the best software for this ?
Thanks !!
You might to a search for viewers. There are quite a few. I use SPLOT ( It works well and is a bit more affordable than the product just mentioned.
AutoCAD allows you to make plot files directly from the print command with no extra software needed.
Choose File, then Plot (or click on the printer icon, either way you prefer), and under the Plot dialog box, choose the 'Plot Device' tab. At the bottom right there is a check box labeled 'Plot to file'. Check the box, and see that the 'File name and path' pull-down menu below becomes active. Simply choose where to save the plot file and name it as you wish, then click 'OK'. This will creat at Plot File (.plt) that can be used by many printing programs to reproduce the drawing.
Making plot files is especially useful when printing multiple sets of plan, as there is no image degradation that you get when reproducing through a scanner. Also, its a great way to archive a plan set.
Thanks Saruman 26
But how do you view it as a plot file without expensive software?
Printing a hard copy would be quite cheap.....
Solidworks 2007 SP5.0
2GB Ram/3GB Switch
Quadro FX1300
P4 3.40GHz Duo XP Pro SP2.0
