Plot controls option 1
balu25
30
I have done a 3-d model of a building for modal analysis. I want to make hard copies of all the shapes, but not manually.
So far i have succeeded just to plot the shapes, but i have problem with making copies of them. If somebody knows how can i make it using an input file, i really can use some help.
I want to make a lot of pictures of my model with different scale for each modal shape, but not manualy. I try to write a macro for this but still can't find the right commands.
Well you might find the following commands helpful then:
*do, *enddo
/contour
set
/ui
That should really be just about everything you need to make a picture taking macro...easy enough i'd say.
Thanks a lot!
The /contour and /ui comands I have missed so far. I hope this time it will be ok!
I have succeded
Thanks again for the help!
