Plit Window Sheets 1
btcoutermash
Industrial
Feb 2, 2004
108
Anyone,
Is it possible when you have multiple sheet drawings to view the sheets in tiled or split window??
No I don't think that is possible... you don't get the SPlit option in a drawing like you do with a part or an assembly.
Scott Baugh, CSWP [pc2]
faq731-376
If you want to view multiple sheets/parts/assemblies, then Window > Cascade, Tile, etc.
Flores
SW 2006 SP1.0
Thank You Scott. I did not think it was possible, but wanted to verify.
You can open a single file in multiple windows. With your drawing open, click menu "Window --> New Window". Now your file is open in two separate windows, and you can view multiple sheets.
[bat]I could be the world's greatest underachiever, if I could just learn to apply myself.[bat]
-SolidWorks API VB programming help
