Plenum Video issue after Solve has run. 1
B4Tack1000
12
Hello
I have been asked to evaluate a Plenum chamber on a turbo charged Race Bike. I have seen on YouTube a way to simulate the 4 outlet ports opening in time with the cam timing. I have completed the solve section and seen in the pre-view the vector arrows changing direction in time with the ports opening. So I believe I have the first section right.
However when I run the video it only plays the last section IE only one port open. I can't seem to get the whole test run in animation.
Link to tutorial on this Youtube
Any ideas?
Thanks.
Hello
I have reduced the test down to it's most basic form to show my issue.
It is now a simple Y tube with the top two ports changing within a time frame.
The screen shot below shows at the start the flow is left at the end the flow is right. But the play back is only were the calc finished IE to right when run to the end or to the left if stopped short while the vectors were moving left.
Any Ideas?
 http://files.engineering.com/getfile.aspx?folder=8d2b86ca-510e-4aaf-bc4c-f2ea21bb956d&file=left_and_rigt_shots.PNG
Yessir! I can help you with this... in fact, I joined this forum just to answer this same question for someone else. What's going on for you is, when the time-dependent solve is finished, by default it loads the very last time moment and displays it. The answer I gave to the other requester covers how to load exactly chosen time moments for individual analysis, as well as how to see the animation you've been missing. Understand that the advice I give using Cut Plots, Isosurfaces, and Flow Trajectories as the examples apply equally to all of the ways that one can create views of the data--- they can all be animated in this same way.
Here is the other post:
"I'm sorry no one stepped in to answer this for you. From what I've seen, so very few people are doing time-dependent analysis there just really is no one to go to for help.
I can help you with where you've been going wrong on this, though.
What you're seeing when you've tried to animate by clicking "play" is one frozen moment in time, put in motion to show what was happening, yes, but only at that one point in time. You want to see a time-dependent result, and if you set up the simulation correctly, you already have the data from many points in time.
Okay, so you know how you have "load/unload results" to get at the dataset... and when you open it, it's the main .fld file you choose, but you can see there are very many numbered .fld files in that data folder as well. The "main" .fld file you choose is the master file for the whole set--- the numbered ones are the specific data for each point in time.
So, when you want to animate (and I would not try this with flow trajectories at first--- use isosurfaces set to temperature or something to "show" the gas; if you do it with flow trajectories, it has to make that minor calculation ("calculating flow trajectories, please wait") that you see when you activate one-- it has to do that for every frame. In my own work, I have one frame for every .01 milliseconds, and I look at about 10 milliseconds of realtime, animating at 100 frames per second--- it's a lot of calculation. Using isosurfaces, it doesn't have to specifically calculate those example trajectories; it just goes off of the fluid results data it already has.
Okay, so near "load/unload results" is that other button with a disk icon called "flow simulation results"--- using the Load Time Moment option there, you can choose any of the .fld files, and thus change which of the moments in your run you're looking at to start with. Still just one moment, but you can spot-check the whole run this way.
Now, to actually animate, create your isosurfaces, your cut plots, what have you, then open the animation creation section either by "animation-insert" or by clicking a plot or isosurface and clicking "animate". Within the animation window, you MUST use the wizard, tiny button next to plus/minus just over the animation window's feature tree. On the first page of the dialogue, click "delete previous tracks" and choose how long you want the animation to take to play. Next choice, skip it, has to do with rotating the model. Then you will have a choice between loaded results (meaning, the ones you already have loaded, that one moment in time), or "scenario". Scenario is the code-word for a time-dependent situation. So choose it. On the next page, choose the "proportional distribution" radio button, and "physical time" next to it. The sliders down below allow you to choose how much of your dataset, in realtime, you want to look at. I model 20 milliseconds from the start of an event, so by default the upper one is set to zero and the lower to 20 ms. So if I want to look at only from 1 ms elapsed until 4 ms elapsed and not more, I adjust each slider accordingly.
When you click "finish", you will see the animation window fill in with small diamonds stretched over the amount of time you specified for the animation--- each diamond is a results node point. You must then insert a control point by hovering over the animation window right by the start line, and level with your entry in the feature tree for "isosurface 1", or whatever. Insert control point and drag until it matches the full length of the animation. It is much easier to do this if you resize, using the plus/minus buttons by the wizard button, to show all the time node points on one page. Once you have the line representing your view (the isosurface or cut plot "control point" you inserted) running all the way under the diamonds as far as the whole animation length, click play and watch it work. The second tab in the animation window is where you can choose the framerate (up to 100 fps) and the filename, should you choose to "record" the animation to disk. If you do so choose, it will play faster and more smoothly--- the animator will do what it can, but it cannot load results at the rate of 100 frames per second, even if you want it to--- those settings will come into play once it has been recorded. "
I hope this gets you going again, and please do feel free to ask if you have further trouble.
Hello
Thanks for the reply, however whe I get this bit:
" On the first page of the dialogue, click "delete previous tracks" and choose how long you want the animation to take to play. Next choice, skip it, has to do with rotating the model. Then you will have a choice between loaded results (meaning, the ones you already have loaded, that one moment in time), or "scenario". Scenario is the code-word for a time-dependent situation. So choose it. On the next page, choose the "proportional distribution" radio button, and "physical time" next to it. The sliders down below allow you to choose how much of your dataset, in realtime, you want to look at. I model 20 milliseconds from the start of an event, so by default the upper one is set to zero and the lower to 20 ms. So if I want to look at only from 1 ms elapsed until 4 ms elapsed and not more, I adjust each slider accordingly."
Then it starts to go wrong as I only get the first and second screen then I get "finish" not other options, I have sw 2010, is this differant to you? I also only have one FLD file in the "load time moment" section not lots as you say above.
I feel I am close but not there yet. Any more advice would be cool.
Hello
Just noticed the "periodic save funtion" was turned OFF, just running again report back soon I hope with some good news.
The "periodic save funtion" was turned OFF and I now get extra options to pick from, however I still can't get the flow to change from one side to another even thou if I load each FLD file it shows the correct point in the calculation and changes from one side to the other. I feel I am very very close now just missing the last thing.
Ok update time.
I have now seen the flow moving from one port to another, "result". However I have read you explanation and warning of using the flow trajectories but can't seam to work that last bit out. Have a lok at the video it shows how far I have got.
Thanks for the help so far.
 http://youtu.be/i1qQZ9J_mwo
